Window motor match need help
My motor on my front window s have not been working trying to find a new one for it the number is 6y1959801 can I use the 6y2959801 is it the same  really hard to get this part are they the same fed up looking add photo of mine had wiring checked and mended still don’t work
  • Sponsor
I think you may have a mk2 Fabia based on that first part number? Does it have 5J as the 7th and 8th digits of the VIN? Driver's door, yeah?
The 6y2959801 part number is used on late mk1 Fabias  for passenger side front on right-hand drive cars. So it will be a 'slave' unit rather than a 'master' unit I think.  It may physically fit, but won't work fully, if at all, I think. There are some differences in the parts on the circuit board inside. Software version is probably different too, but I don't know how much that matters.
Edited by Wino
This is mine it as got it on the inside door I just need to know if a different number with same  connection will work on mine as I can’t find one 6ED9FC7A-443B-40AF-B1CE-A49A0A3F854F.thumb.jpeg.3d7bc80bea86a5d49daa23ef19671524.jpeg
