vRS clocks, upgrades?
In the old Golf 4 we fitted Bira Sport clocks (full fis) and had them reprogrammed for needle sweep and stuff...
What are the potential upgrade options, if any, for the standard vRS clocks?
I like to keep things looking more or less standard looking but with some tweaking where possible.
  • Administrators
Only options I know are the FIS (MFD1) which was £1500 optional extra and comes with the Satnav.
This mine:
You can find virgin units or even order them from Skoda/TPS but they will cost a bomb.
So the other options is to go aftermarket with something like the Color3DMFD.
Full colour change.
Prices start at around £250 and you’d need to send the clocks away to get them done or if you’re handy at soldering, there’re instructions to do it yourself.
Needle sweep will depend on which type of cluster you have (version).
Edited by DeanVRS20VT
Thanks chaps.. :cool:
I was looking at ardtechniks colourmfa (thought about it for the Golf) and I could probably do the soldering but I'd rather not.. with fitting it's well north of £500 - especially when you factor in some pretty colours for the clocks.
Stumbled across FIS Control last night too.. looks interesting, and only £300, but I'd still need the centre display.
Wondering if I could fit the full display, likely available from aliexpress for buttons, into the stock clocks and install that.
What bugged me, and this is a bit daft, was that the door open telltale doesn't indicate which door is open.
And the computer using the clock display is a bit irritating too.
If it was a cheap and easy option I'd have at it, otherwise it's very low priority..
Sorry to bump this...
Would 1u0920841b clocks plug and play??
