Wheel bearing question
2010 Yeti S with CFHA - I need to change the front wheel bearing.
Searches of various parts catalogues give differing results, so can anyone tell me whether this part is fixed in place by 3 or 4 bolts?
  • Sponsor
Unfortunately, the front brake PR code is rarely given on the build sticker.
Funny you should say that ...
You are correct Wino, I have the 280mm brakes & bought calipers & discs (320mm?) from a Golf GTi to upgrade but my hub carriers & suspension struts also need changing, mine have the 3 bolt bearing.
I could change just the hub carriers as tubular spacers are available for the struts.
So is there a rule of thumb here, for example - 2wd = 3 bolts, 4wd = 4 bolts?
  • Sponsor
Don't think so; just 280mm front discs 3-bolt, any other size 4-bolt, as far as I could see.
So, after getting down on my hands and knees with a torch the result for my 2wd 110hp 2.0tdi with 'ordinary' rather than GTI brake size is ....
(drumroll)
3 bolts
The same as my 4wd version with the same power.
It limits your ability to upgrade the brakes or makes it a lot more difficult and expensive.
Edited by J.R.
Not sure I'm bothered about those performance upgrades anymore, I'd rather have MFSW, armrest box and an RCD360 :)
Me too, an Ali-Express armrest box was one of the first purchases.
The brakes are adequate but not inspiring, I have a trio of unbraked site hut type trailers that I will be using to move my tools & machinery from my UK garage to France, I wanted to have confidence in the vehicle brakes.
