Octavia Mk2VRS TDi Ignition Issue - VCDS Codes
Hi All,
I have a Octavia Mk2 with an ignition issue.
The car previously cut out whilst driving but would restart and continue for a short distance, the fault was diagnosed as the crank sensor which was replaced.
It ran fine for around 500 miles before randomly cutting out again, this time the codes are for the ignition switch, a replacement part has been fitted but the codes come back.
Any help would be appreciated.
The codes are as below:
5 Faults Found:
00576 - Terminal 15
            012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
