More Extra info climatronic
By pressing the AC and Screen button I get an extra screen in the info. Seems to give temperature reading and also relates to rear.
Anyone know what can be done with this setting or what it actually is.
You can't do anything with it. It's just a display of the climate settings that pops up when you change something.
Hold the AC and the screen buttons you get the self check flash similar to holding Ac and front vents...
However this screen is not standard and appears to show temperature options and rear vents locked or no lock.
Also just to add, you might notice the temperature on the photo is 19.7
I dont think you usually see the .7 bit.
And the photi relates to rear...ahain not usual I believe.
Edited by harryrope
Spelling
