Fabia VRS issues!
10 hours ago, UrbanPanzer said:
I don't see why they could not time it without the VVT.
It was not "out of time" before they did the chain was it............
Have they worked on these engines before ?
No but it was missing/stuttering it went to the garage to see about the water leak and to make sure it wasn’t head gasket
I don’t think they have TBH now at all!
It's a load of smoke and mirrors, they don't know what they're doing, probably didn't have the necessary locking kit so they improvised and messed it up.
If it's exactly the same as before then they've done nothing at all except take your money, then take some more, they're hoping you'll just go away so expect the sums they want to be increasingly eye-watering, it'll be a new ECU next.
It’s sorted fuse blown for coil packs and one had split! Now radiator change is it right these are waterless coolant systems and is it G13? Thanks
No it's not waterless coolant, yes G13 will be just fine.
G13 is waterless!
G13 is waterless!
The concentrate is of course, but you're supposed to dilute it with DI water 50/50.
