Fitting Octavia mk3 rs parts to Fabia mk3
I was wondering if octavia/octavia mk3 rs parts would fit to my mk3 Fabia. For example maybe the front lips from kopacek would be possible to fit? They look very much the same shape. Or how bout fitting rear diffusor.
Also interested in other rs parts that could fit to my Fabia :)
The cars are a very different width so using a tape measure against an Octavia and a Fabia would be a good start to seeing if the parts used from one on the other is viable.
Yea, prolly should start with measuring :biggrin:, has anyone fitted a rs flat bottom steering wheel to a Fabia ?
The Octavia is wider than the Fabia, I am pretty sure the bumper profiles are different too.
Magnatuning do some splitters and diffusers for the Fabia, may be worth a look.
There is a flat bottom steering wheel in the 'Red Line' trim Fabia, it would all come down to the wiring aspect.
Fabia Monte Carlo comes with a flat bottomed steering wheel too so don't forget to look at other spec levels for extras.
The flat bottom wheel on the Octavia is the same as the Fabia Monte. Only difference is the VRS is grey stitch and the Monte is Red stitch. Also the Octavia one if automatic will have DSG paddles.
I replaced my stock Fabia wheel with the Monte Flat bottom wheel. It is a direct replacement.
Steering wheels will fit, some airbags are the same. I've got a mk3 Octavia VRS wheel with DSG paddles on my Fabia
