1956515 size tyre on mk1 fabia estate
Hi guys,
Will putting above size tyres on my 1.9 TDI estate 2007 mk1 fabia cause any damage. Will there be enough clearance on top between the tyre and suspension strut?
I am not concerned about off roader look as profile is quite thick at 65.
They are going on standard steel wheels.
Many thanks in advance.
They won't fit, much too tall.
A few years ago I got a set of Avus 2 alloys from a mk iv vw golf (ET35) with the above mentioned specs, 195/65 R15. I knew from the start the size was bad, but it was a temporary setup. I had no issues or whatsoever while I ran with those tires.
L.E.: it was a hatchback, not an estate.
Edited by Alexandru
I will look at my steel wheels et size
8y ago it was looking like this.
Thanks .
While you had these on- did they end up scratching or hitting against any suspension part etc.
Or any damage on suspension parts?
Your speedo will be hopelessly inaccurate and the front tyres will foul the arch on full lock, also your acceleration will be much slower.
They are the wrong size, @Alexandruis a wild man, best advice is NOT to fit them.
Yup, they were wrong, car wasn't handling good, but I was able to run with them for a few months until I purchased 195/50, which is the correct size.  As per suspension parts, I did not notice anything which might have gone wrong.
Edited by Alexandru
3 hours ago, Alexandru said:
A few years ago I got a set of Avus 2 alloys from a mk iv vw golf (ET35)...
15" rims from the Golf MK4 have always had an ET38 offset, including the Avus 2
1 1J0601025B aluminium rim 6 JX15H2 ET38
5/100
Model data: PR-C6V
  1J0601025B 091
Cancelled since 01.11.2002
chrome coloured metallic
Period: 1097 - 0601
1 1J0601025AA aluminium rim
- AVUS -
6 JX15H2 ET38
5/100
  1J0601025AA091 chrome coloured metallic
Period: 1097 - 0601
2 1J0601025Q aluminium rim
-AVUS II-
6 JX15H2 ET38
5/100
Model data: PR-C3J
  1J0601025Q Z31
Cancelled since 01.06.2014
bright chrome
Period: 0500 - 0601
4 1J0601025AL aluminium rim
-JARAMA-
6 JX15H2 ET38
5/100
Model data: PR-C3H
  1J0601025ALZ31
Cancelled since 01.10.2004
bright chrome
Period: 0500 - 0601
5 1J0601025AG aluminium rim
- BBS -
6 JX15H2 ET38
5/100
Model data: "J..":PR-CG8
  1J0601025AGZ31 bright chrome
Period: 1097 - 0601
http://www.oemepc.com/vw/part_single/catalog/vw/markt/RDW/modell/GOLF/year/1998/drive_standart/203/hg_ug/601/subcategory/601051/part_id/3688046/lang/e
Edited by Carlston
oh nice find. I always thought those have been et35. my bad.
Offset on standard steels seems to be 43mm. They'll sit "in" further by 5mm than Alexandru. You may need spacers if you do it.
Why are you doing 65 profile exactly?
