Question on Central lock system + Lights
Hi,
So I heard of the feature called 'Anti Hijack' which could be enabled through VCDS. I assume this means only the driver door opens first and then all other doors.
I enabled it and it works.
Recently, I sat inside the car and locked it with the button on the key. I then tried to open the door and it doesn't open!
Q1. Is that usual the usual behavior?
Next .. There is an option to enable chirps on lock and unlock. I enabled it but there are no chirps! Also, I could never get the alarm to go off. I tried a firm bang on the car and nothing.
There is a red led on the drivers door which blinks when the car is locked.
Q2. How can I check if my car has the security system which beeps and how do I enable chirps on lock? Is there a way to enable panic mode from the key fob? (I do not have the red panic button on the fob).
Next.. I've enabled coming home and going away lights and I see it on the maxi dot, configured to 10 seconds. It doesn't seem to work when I lock/unlock the car.
Recently, on an other thread, I saw a mention of this working with the 'auto' position on the light switch.
I have all the sensors for rain sensing wipers and auto dimming rear view mirror but do not have the 'auto' option on my headlights switch.
Q3. Do I have to get a switch with the 'auto' position (and set that up) for coming home and going away lights to work? If not, what can I try?
Sorry for the messy thread, not sure if I should break this down into it's own thread (I can't for the life of me find the answers to these).
Thanks!
PS: I have a 2009 Skoda Octavia Facelift, Elegance (Ireland)
Press the lock button twice in quick succession and the deadlocks won't be activated.
I always thought anti hijack was when the doors auto lock above a set speed.
Ah that doesn't work for me. No matter how quick I double press, I always hear the car locking on the first press and does nothing on the second.
That actually makes sense! I have that enabled. The coding says auto lock at 20kmph but my car locks at 15kmph. That's cool though.
Try again.
On 29/05/2021 at 22:32, AnirudhAppala said:
I sat inside the car and locked it with the button on the key. I then tried to open the door and it doesn't should open!
If the ignition was on then that is option.
Carista allows to choose:
Enable remote control buttons when ignition is on
Yes / No
I don't know what happens when the ignition is off but easily tested as pressing the lock button above the gear lever works exactly the same way as the remote.
21 hours ago, john999boy said:
Try again.
Same result again :thinking: Does nothing and I'm locked inside with the deadbolts enabled.
Yes / No
I disabled the remote buttons when inserted into the ignition.
When I lock myself inside with the remote and then insert the key and turn it to the on position, the doors unlock automatically!
But, If I lock myself inside without inserting the key in the ignition, the door handles do not open the door and also the lock/unlock switch under the parking break does nothing when pressed.
Thanks for your responses!
Maybe you should post an autoscan from VCDS so we can see how your car is equipt and configured :)
Ah darn it that's a great idea! I'll post that here tomorrow.
Thanks!
Here it is.
OBDeleven vehicle history log
Date: 2021-06-02 22:32
    VIN: TMBBS21Z092009794
    Car: Skoda Octavia
    Year: 2009
    Body type: Saloon
    Mileage: 246530 KM
Backup
    Control unit: 01 Engine
    System description: R4 1,9l EDC G000SG
    Software number: 03G906021TB
    Software version: 2047
    Hardware number: 03G906021AN
    Backup name: Engine
    Coding:
        0000071
    Adaptations:
        Channel 006: 830
        Channel 016: 300
        Channel 017: 300
        Channel 018: 300
        Channel 019: 0
        Channel 020: 200
        Channel 021: 200
        Channel 022: 0
        Channel 050: 32000
        Channel 091: 4
        Channel 128: Secured
        Channel 129: Secured
        Channel 130: Secured
        Channel 131: Secured
        Channel 132: Secured
        Channel 133: Secured
        Channel 134: Secured
        Channel 135: Secured
        Channel 136: Secured
        Channel 137: Secured
        Channel 138: Secured
        Channel 139: Secured
        Channel 140: Secured
        Channel 141: Secured
        Channel 142: Secured
        Channel 143: Secured
        Channel 144: Secured
        Channel 145: Secured
        Channel 146: Secured
        Channel 147: Secured
        Channel 148: Secured
        Channel 149: Secured
        Channel 150: Secured
        Channel 151: Secured
        Channel 152: Secured
        Channel 153: Secured
        Channel 154: Secured
        Channel 155: Secured
        Channel 156: Secured
        Channel 157: Secured
        Channel 158: Secured
        Channel 159: Secured
        Channel 160: Secured
        Channel 161: Secured
        Channel 162: Secured
        Channel 163: Secured
        Channel 164: Secured
        Channel 165: Secured
        Channel 166: Secured
        Channel 167: Secured
        Channel 168: Secured
        Channel 169: Secured
        Channel 170: Secured
        Channel 171: Secured
        Channel 172: Secured
        Channel 173: Secured
        Channel 174: Secured
        Channel 175: Secured
        Channel 176: Secured
        Channel 177: Secured
        Channel 178: Secured
        Channel 179: Secured
        Channel 180: Secured
        Channel 181: Secured
        Channel 182: Secured
        Channel 183: Secured
        Channel 184: Secured
        Channel 185: Secured
        Channel 186: Secured
        Channel 187: Secured
        Channel 188: Secured
        Channel 189: Secured
        Channel 190: Secured
        Channel 191: Secured
        Channel 192: Secured
        Channel 193: Secured
        Channel 194: Secured
        Channel 195: Secured
        Channel 196: Secured
        Channel 197: Secured
        Channel 198: Secured
        Channel 199: Secured
        Channel 200: Secured
        Channel 201: Secured
        Channel 202: Secured
        Channel 203: Secured
        Channel 204: Secured
        Channel 205: Secured
        Channel 206: Secured
        Channel 207: Secured
        Channel 208: Secured
        Channel 209: Secured
        Channel 210: Secured
        Channel 211: Secured
        Channel 212: Secured
        Channel 213: Secured
        Channel 214: Secured
        Channel 215: Secured
        Channel 216: Secured
        Channel 217: Secured
        Channel 218: Secured
        Channel 219: Secured
        Channel 220: Secured
        Channel 221: Secured
        Channel 222: Secured
        Channel 223: Secured
        Channel 224: Secured
        Channel 225: Secured
        Channel 226: Secured
        Channel 227: Secured
        Channel 228: Secured
        Channel 229: Secured
        Channel 230: Secured
        Channel 231: Secured
        Channel 232: Secured
        Channel 233: Secured
        Channel 234: Secured
        Channel 235: Secured
        Channel 236: Secured
        Channel 237: Secured
        Channel 238: Secured
        Channel 239: Secured
        Channel 240: Secured
        Channel 241: Secured
        Channel 242: Secured
        Channel 243: Secured
        Channel 244: Secured
        Channel 245: Secured
        Channel 246: Secured
        Channel 247: Secured
        Channel 248: Secured
        Channel 249: Secured
        Channel 250: Secured
        Channel 251: Secured
        Channel 252: Secured
        Channel 253: Secured
        Channel 254: Secured
        Channel 255: Secured
    Mileage: 246530 km
    Date: 2021-06-02 22:11
Backup
    Control unit: 03 Brakes
    System description: MABS MK70M
    Software number: 1K0907379AF
    Software version: 0104
    Hardware number: 1K0907379AF
    Backup name: Brakes
    Coding:
        0016641
    Adaptations:
        Channel 073: 1
        Channel 088: 1
        Channel 093: 0
    Mileage: 246530 km
Backup
    Control unit: 08 Air Conditioning
    System description: Climatronic
    Software number: 3T0907044AB
    Software version: 0203
    Hardware number: 3T0907044AB
    Hardware version: 122
    ODX name: EV_Climatronic
    ODX version: A01001
    Backup name: Air Conditioning
    Long coding:
        0100000000
    Adaptations:
        Duration of compressor run in:
                0 s
        Analysis 1:
                0
        Retention of driver's seat heater level:
                not active
        Runtime for compressor run-in basic setting:
                1 s
    Advanced identification:
        Program memory status:
            Error in flash memory:
                No
            Flash memory faulty:
                No
            Communication error:
                No
            Flash memory not programmable:
                No
        Number of programming attempts:
                0
                0
                0
        Number of successful programming attempts:
                0
                0
                0
        Maximum number of possible update programming:
            Number of possible flash attempts:
                0
                0
                0
        Workshop code and date of last update programming of SW module:
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                Correct result
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                Correct result
        Running manufacturer number:
                0015
        Date of last coding:
            Year:
                0
            Month:
                0
            Day:
                0
        Manufacturer- test stand number:
                0002
        Manufacturer modification status:
            Control module family:
                0
            Decoration variant:
                0
            Construction version:
                003
            Manufacture version:
                001
        Manufacture location index:
                BHB
        Identification of standard software:
            Standard software module:
                BAP
            Primary version number:
                1
            Secondary version number:
                4
            Revision number:
                0
                UDS - protocol
                1
                2
            Revision number:
                11
                Diagnostics - Event - Handler
                1
                2
            Revision number:
                3
                CAN - driver
                1
                11
            Revision number:
                6
                ISO15765-2
                1
                2
            Revision number:
                11
                OSEK - Network management
                3
                69
            Revision number:
                1
        VW/Audi part number:
                3T0907044AB
        SoftwareVersion:
                0203
        Day of manufacture:
            Year:
                8
            Month:
                10
            Day:
                29
        Hardware part number:
                3T0907044AB
        System description:
                Climatronic
        Adaptation workshop code:
            Device number:
                0
            Importer number:
                770
            Dealership number:
                73216
        Date of last adaptation:
            Year:
                0
            Month:
                0
            Day:
                0
        ASAM/ODX file identification:
                EV_Climatronic
        ASAM/ODX file version:
                A01001
        HardwareVersion:
                122
        Coding workshop code:
            Device number:
                0
            Importer number:
                770
            Dealership number:
                73216
        System abbreviation:
                J255
        Installed condition documentation:
            Hardware subassembly:
            Hardware sorting key:
            Software subassembly:
            Software sorting key:
            Variant of software type:
        Programmability status:
            Programmability:
                programmable
            Program consistency:
                Program present
        Versions of software module:
                U
    Mileage: 246530 km
Backup
    Control unit: 09 Central Electrics
    System description: BCM PQ35  H
    Software number: 1K0937087
    Software version: 0358
    Hardware number: 1K0937087
    Hardware version: 020
    Backup name: Central Electrics
    Long coding:
        54180AB8D82708C0400800801100816C076800AE527D8160000540000000
    Subsystems:
        Subsystem: Wischer 15080
        Long coding: 00D7B7
        Subsystem: RLS 211008 05
        Long coding: 0730ED
    Adaptations:
        Channel 004: 1
        Channel 005: 0
        Channel 006: 1
        Channel 007: 0
        Channel 012: 1
        Channel 017: 1
        Channel 019: 0
        Channel 022: 0
        Channel 023: 10
        Channel 024: 10
        Channel 025: 15
        Channel 029: 0
        Channel 031: 5
    Mileage: 246530 km
Backup
    Control unit: 10 Parking Assistance
    System description: PARKHILFE 4K
    Software number: 1Z0919475
    Software version: 0004
    Hardware number: 1Z0919475
    Hardware version: H06
    Serial number: 66640829102355
    Backup name: Parking Assistance
    Long coding:
        000001
    Adaptations:
        Channel 001: 4
        Channel 002: 4
        Channel 007: 1
        Channel 008: 1
        Channel 010: 1
        Channel 011: 0
        Channel 023: 10
    Mileage: 246530 km
Backup
    Control unit: 15 Airbag
    System description: Q4 AIRBAG VW8   020
    Software number: 1K0909605T
    Software version: 2300
    Hardware number: 1K0909605T
    Hardware version: 003
    Serial number: 0038PD28CJKO
    Backup name: Airbag
    Coding:
        0020788
    Adaptations:
        Channel 001: 0
        Channel 002: 0
        Channel 003: 0
        Channel 004: 0
        Channel 005: 0
        Channel 006: 0
    Mileage: 246530 km
Backup
    Control unit: 16 Steering Column
    System description: J0527           055
    Software number: 1K0953549CF
    Software version: 0111
    Hardware number: 1K0953549CF
    Backup name: Steering Column
    Coding:
        0000732
    Subsystems:
        Subsystem: E221__MFL-URO   H07
        Coding: 0000130
    Mileage: 246530 km
Backup
    Control unit: 17 Dashboard
    System description: KOMBI
    Software number: 1Z0920843D
    Software version: 0106
    Hardware number: 1Z0920843D
    Hardware version: X20
    Serial number: 00000000000000
    ODX name: EV_Kombi_UDS_VDD_RM09
    ODX version: A04040
    Backup name: Dashboard
    Long coding:
        110B00
    Adaptations:
        Activating and deactivating all development messages:
            Development messages:
                not active
        Distance:
            Distance:
                246530 km
        WIV: Coding of Service Interval Extension (SIE):
            Status ESI or SID:
                ESI or SID on
            Selection of ESI or SID:
                Extended Service Intervals (ESI)
            Oil level:
                Oil level evaluation
            oil pressure:
                Dynamic oil pressure
            Remote clock receiver:
                Without remote clock receiver
            Oil quality:
                Poor oil quality
            TOG:
                Oil level thermal sensor connected to instrument cluster
        WIV: Resetting ESI:
                Reset
        Language version:
                English
        Display correction of consumptions and operating range:
                100 %
        Seat belt warning:
            Gurtwarnung:
                Version 2
        Hour:
                22 h
        Minute:
                2 min
        Display correction of fuel gauge:
            Anzeigekorrektur Kraftstoffvorratsanzeige:
                0.0
        Speed threshold of dynamic oil pressure warning:
            Offsetwert:
                kein Offset
        SIE: distance driven from inspection:
                3900 km
        SIE: time from inspection:
                103 d
        SIE: oil quality:
                Poor oil quality
        SIE: soot entry:
            m-Aequivalent0..819100 in 100km:
                7300 km
        SIE: thermal load:
                3000 km
        Additional coding:
            Speed source:
                via CAN
            Coolant temperature source:
                via CAN
            Locking bit:
                locked
            Tank characteristic curve:
                1
            Number of fuel level sensors:
                1
        SIA: maximum value of distance to service:
                15000 km
        SIA: maximum value of time to service:
                372 d
        Staging:
            Inszenierung:
                active
                No
                No
                No
                No
                0
                0
                0
                0
                0
                0
                0
                0
                0
                0
                0
                0
                0
                0
                0
                0
                0
                0
                0
                0
            Bootloader:
                1000
            Application:
                1000
            Data record:
                1000
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                00
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                00
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                00
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                00
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                00
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                00
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                00
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                00
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                00
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                00
        Subassembly and series number:
            ECUSupplierNumber:
                0346
            Year:
                0
            Month:
                0
            Day:
                0
        FAZIT-identification:
                VD1-048
            Day of manufacture:
                03.11.08
                3911
                0346
        Manufacturer's test stand number:
            ECUProductionTestSystemNumber:
                3911
            VWSupplierNumber:
                VD1
                BAP
                1
                4
            Revision number:
                1
                OSEK - operating system
                3
                14
            Revision number:
                0
                High Speed - Network management
                1
                10
            Revision number:
                0
                1Z0920843D
        SoftwareVersion:
                0106
        Date of manufacture:
            Year:
                8
            Month:
                11
            Day:
                3
        Serial number:
                00000000000000
        Vehicle Identification Number (VIN):
                TMBBS21Z092009794
                1Z0920843D
        System description:
                KOMBI
            Device number:
                60933
            Importer number:
                3
            Dealership number:
                13312
            Year:
                21
            Month:
                4
            Day:
                30
                A04040
        HardwareVersion:
                X20
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
                J285
                0008
                0006
                0006
                0000
                0000
                0000
                0000
                0000
                0000
                0000
            Programmability:
                programmable
                Program present
        Consistency of EEPROM-data:
            Data consistency:
                valid EEPROM data
            Error during last data record download:
                no error
            Data record modification:
                Data record not changed
            Parameterizability:
                Parameterizable
    Mileage: 246530 km
Backup
    Control unit: 19 Gateway
    System description: J533__Gateway   H16
    Software number: 1K0907530S
    Software version: 0210
    Hardware number: 1K0907951
    Serial number: 3400K08A1400EB
    Backup name: Gateway
    Long coding:
        E9A07F06000202001303
    Mileage: 246530 km
Backup
    Control unit: 25 Immobilizer
    System description: IMMO
    ODX name: EV_Immo_UDS_VDD_RM09
    ODX version: A03004
    Backup name: Immobilizer
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                Correct result
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                Correct result
            Year:
                0
            Month:
                0
            Day:
                0
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                Correct result
                VD1-048
            Day of manufacture:
                03.11.08
                3911
                0346
                BAP
                1
                4
            Revision number:
                1
                3
                14
            Revision number:
                0
                1
                10
            Revision number:
                0
                1Z0920843D
        SoftwareVersion:
                0106
        Serial number:
                00000000000000
                TMBBS21Z092009794
                1Z0920843D
        System description:
                IMMO
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Year:
                0
            Month:
                0
            Day:
                0
                A03004
        HardwareVersion:
                X20
                J334
                0008
                0006
                0006
                0000
                0000
                0000
                0000
                0000
                0000
                0000
            Programmability:
                programmable
                Program present
    Mileage: 246530 km
Backup
    Control unit: 42 Driver Door
    System description: Tuer-SG         008
    Software number: 1T0959701N
    Software version: 2004
    Hardware number: 1T0959701N
    Backup name: Driver Door
    Coding:
        0004854
    Mileage: 246530 km
Backup
    Control unit: 44 Steering Assistance
    System description: EPS_ZFLS Kl. 69
    Software number: 1K0909144C
    Software version: 2301
    Backup name: Steering Assistance
    Adaptations:
        Channel 000: 1
        Channel 001: 0
        Channel 002: 0
        Channel 003: 1
        Channel 004: 2
        Channel 005: 0
        Channel 006: 0
        Channel 007: 0
        Channel 008: 0
        Channel 009: 0
    Mileage: 246530 km
Backup
    Control unit: 52 Passenger Door
    Software number: 1T0959702N
    Software version: 2012
    Hardware number: 1T0959702N
    Backup name: Passenger Door
    Coding:
        0004854
    Mileage: 246530 km
Backup
    Control unit: 56 Radio
    System description: Radio
    Software number: 6RD035187B
    Software version: 5814
    Hardware number: 6RD035187B
    Hardware version: 541
    Serial number: VWZZZ4H6290655
    Backup name: Radio
    Long coding:
        16000400040005
    Adaptations:
        Channel 002: 0
        Channel 003: 30
        Channel 005: 0
        Channel 010: 0
        Channel 036: 6
        Channel 047: 3
        Channel 050: 0
    Mileage: 246530 km
Backup
    Control unit: 62 Rear Left Door
    System description: Tuer-SG         006
    Software number: 1K0959703J
    Software version: 1301
    Hardware number: 1K0959703J
    Backup name: Rear Left Door
    Coding:
        0000144
    Mileage: 246530 km
Backup
    Control unit: 72 Rear Right Door
    Software number: 1K0959704J
    Hardware number: 1K0959704J
    Backup name: Rear Right Door
    Coding:
        0000144
    Mileage: 246530 km
I see somewhere it says 'Poor Oil Quality'.
Not sure what that is.
'Poor oil quality' just means your on fixed rather than variable servicing. It has no relation to the actual oil quality.
There is no alarm siren in your car so you won't be able to have lock/unlock chirps. You might be able to use the horn instead but I wouldn't recommend it as it's loud compared to the chirps
Yes, if you want proper CH/LH lights you need an auto light switch and possibly an extra wire between it and the BCM. You should then be able to code them in.
That's interesting!
Thanks. I like the re-assurance of the chirps and will look at adding this as a retrofit, later this year.
Thanks for the confirmation. I'll retrofit that as well.
Anything in the auto scan points to the above?
This seems to do nothing for me.
Can't say I ever tried locking myself in the car then trying to get out :D
It feels like normal behaviour due to the deadlocks though. As John mentioned, double tapping the lock button within 2 seconds should prevent the deadlocks but you may need to pull the door handle twice to get out.
It's all covered in the owners manual under 'safe securing', might be worth a read to compare with your cars behaviour.
That did it!
Finally figured it out. I had to press the lock button a second time, a second after the first. I was pressing a lot sooner before. The deadbolts retract just fine now!
Haha! I only figured it out when I locked a friend inside, assuming they could get out when they want but no!
All my questions are answered! Thanks everyone :)
