Just put new engine in
Now idle is around 1000rpm how do I code everything to work I have acces to coding tool
You’re gonna need to put a lot more details about what engine, what you replaced and why?
if you’ve fitted the same engine exactly and not changed any electrical components you won’t need to code anything, just adapt the throttle body and reset all other adaptations.
But we really need more detail than that
It’s from a different car but same engine code CRLB but different injectors new alternator and battery
Has the engine ecu module 01 been changed? If so, compare coding and adaptation maps between old and new for differences
No it has not been changed
