Fabia MkII S 1.2 3cyl 70 bhp Timing Chain Replacement Query
Looking for some advice on the importance of replacing the timing chain on our 2010 Fabia 1.2S 70bhp 3 cyl.  It has done 55,000 miles.
I suspect my local non franchise VW/Audi specialist will quote £400 to replace the timing chain which seems a lot for a car worth £2k.
Is it worthwhile ? What are the chances of the chain breaking ?  I know it will be a write off if it does happen.
Would really appreciate some wise advice.  Thanks.
  • Sponsor
Leave it alone for the next 100k miles, but keep the oil clean and correct spec.
Thanks for such a quick reply !
  • Sponsor
No problem.
Coilpacks are possibly the most vulnerable parts on these engines, so consider buying a spare, and a handheld code-reader. Keep both in the glovebox then you have a fair chance of re-mobilising yourself if you ever break down due to a failure of one.
If you're not DIY-minded and have breakdown cover, it might save a bunch of time by the side of the road if you have a spare ready to be fitted for you.
