Skoda Fabia Abs light and brake noises
Hello, I have a problem with my skoda fabia 1.4 TDI for about a year now.
Every time I turn it on, the first few minutes I drive, every time I brake the brakes make a metallic noise and I feel pressure on the brake pedal.
After that time the ABS light turns on and the pedal becomes lighter and stops making noise, however I notice that the ABS is deactivated.
Has anyone been through the same?
  • Sponsor
Do you have the same size wheels and tyres in all 4 corners?
You possibly have a faulty sensor or wheel bearing. If you get a scan for fault codes while the light is on, this should point you in the right direction.
yes I have :) I try change the ABS sensor of wheel velocity on the whell that makes more noise braking but the problem does not desapear :S
I try read the codes with a bluetooth ODB II code reader  and and app on my phone, but the app says it's everything ok =/
You'll maybe need a more advanced scanning tool like VCDS that can get more info from the car.
