Padsm sticking with Bremno
I need to change my front discs and pads. I’ve measured the disc at 312 mm and as I’m sticking with Brembo  parts they list two types of pad. Does anyone know the correct PR code for these ?
Afaik, the Brembo pads are likely to be in two series 'normal' and Xtra., the Xtra ones probably have a part number that ends in a an X (although you'd feel happier if the supplier listed that information directly for you.)
This X or not X is unconnected with the PR number, and you need to stick with the listed one for your vehicle, unless the callipers have been changed, in which case you are in a whole world of confusion...
At least, I think you can get both X and non-X parts in the common PR-code fitments, although inevitably some will be more difficult to find than others.
Many suppliers don't make this at all clear.
GSF lists two types. None of their PR code numbers match my service book ones. Looking closely at the fitment details it seems one has a wear marker the other Intergrated wear device
Yes, I have the same situation where the front PR code isn't listed in the book, or on the rear sticker, and it is bizarre. Quite how this is helpful to anyone, I just don't know.
It would probably cause less confusion not to list either the front or the rear, because you think - at least I did, that one of the codes that you do have must be the front, because you can see the rear.
Spoke to local GSF shop and all sorted. Picking up parts tomorrow. GSF offer good discount on online orders only.
