Shortened droplinks
Hi all,
I'm currently running bc racing coilovers on my 07 vrs. I need shortened droplinks, as the factory ones are too long and cause issues. Can anyone recommend some that are fixed length rather than adjustable ones I have currently?
What's wrong with the adjustable ones?
I'm on my second set in less than 12 months. I'm open to suggestions of decent adjustable ones. Even though the ones I'm using cost £40 the pair.
Presumably the ball joints are failing and not the adjustable part, just buy regular items and cut/weld to suit.
Yeah it's the ball joints that are giving up. I know there are some from a different vehicle that fit and are shorter, but can't remember which ones it is.
Pop down to your local motor factor and explain you want to compare items, could be any of the sportier VAG models.
If they're not overly busy I'm confident they'll help.
Whiteline heavy duty adjustable drop links, you have to pay to play though!
