Injection quantity deviation figure after injector change MK2 1.6 tdi
Hello guys.
After changed the faulty number 1 injector to a new one, car starts to get better mpg.
From the memory, while reading the the faulty one' deviation figure, it was like +5mg.
Yesterday, I tried on  the cold engine, the number 2 injector was between +1.8 to+2mg.
On the warmer engine, I got following ones. Both taken while engine was in idle.
Is the number 2 injector on the way out or its in the normal range?
On the coding the injector using the vcds, I put extra 0 after the six digits like the rest injectors setting, is this correct?
Thanks in advance.
18:30:53
  IDE00025 Coolant temperature 74 °C
  IDE00365-ENG99400 Injection quantity deviation cylinder 1-FAC_CYL_BAL1 -0.4484 mg/stroke
  IDE00366-ENG101187 Injection quantity deviation cylinder 2-FAC_CYL_BAL2 1.1234 mg/stroke
  IDE00367-ENG101684 Injection quantity deviation cylinder 3-FAC_CYL_BAL3 -0.3832 mg/stroke
  IDE00368-ENG103465 Injection quantity deviation cylinder 4-FAC_CYL_BAL4 -0.1870 mg/stroke
