Electric window problem
Hello the electric windows have started playing up. I changed the switch on the driver side and it worked fine along with the passenger one due to being warn out.
I watched a film clip on utube how to make the windows work again by un plugging the connector in the driver door loom. I do this the windows work fine but soon as you switch the engine of the problem back unless you unplug the connector again. So is there a control or relay box problem on these cars?
Skoda fabia 1.4 tdi 2006 Thanks
  • Sponsor
This often seems to come down to replacement of the driver's side motor module, which tends to be very expensive, even secondhand. :crying:
Hello there a easy guide or way to test the electric window motor?
  • Sponsor
Not sure about easy, but probably the most conclusive test is to swap it into a car where the windows work correctly and see if they still do, reliably.
It would need to be a Mk1 Fabia with the same part number module, so a car from about 2005 onwards.
Conversely, if you have access to such another Fabia, test-swap their module into your car and see if everything now works in yours.
  • Sponsor
Check cabin fuse 11, if you haven't already.
I will check that fuse again thanks
So the part number has to match even if its from the same model cars?
  • Sponsor
Yes.
