J271 Relay
Hi
Does anyone know where the J271 relay is located on my skoda Octavia 2009 1.8 tsi  Engine code CDAA
Got a code001674 Power relay load circuit  J271
  • Sponsor
Hi, and welcome to the forum. I'll give that a go. Bear with me. :)
Symptoms other than the code?
Hi Wino
Thanks for quick reply
Very slight shaking on idle but no other symptoms just check engine light
I have also got codes 000369 system too lean sporadic and 001089 Evap emission incorrect flow
Regards
  • Sponsor
Relay position 1, nearest the middle of the fusebox under the bonnet.
Doubt there's any relevance to the other fault codes, but who knows.  Check fuse 10 in the same fusebox for looseness or dirty/corroded contacts as it feeds the relay coil.
Purge valve slight misbehaviour or hose leakage is a possibility for the observed symptoms/other codes.
Another is brake servo vacuum hose.  Always worth a look/feel, in case there are splits in the hard plastic sections of the pipe run, at junctions with other items like non-return valve.  VW group don't cover themselves in glory by the design/materials of these, unless planned obsolescence is the intention...
Edited by Wino
sp
Great Info Thanks
Found the relay and fuse 10 looks ok
Do you know where to buy a new relay and purge valve
The  brake servo is difficult to get to but cant feel any cracks, I might have to cut the silver insulation cover and have a better look  , does the servo hose just pull out
Again Many thanks for your help
