amp turning on and off
any time as long as its turned up enough like say about 23-24 on the volume
here's the latest moved ground to cd changer bracket cleaned off paint still no better so i cranked it uop on drive and i could see the light on the amp actually turn on and off with the sound checked the voltage to the amp still no good so i think the amp is dicky so i taking it back now
sounds like a good idea, without actually looking it seems to a fair thing to do now :)
as usual it didnt do it out side the shop so i really don't know now i'll try moving the earth again to the boot catch i getting pi55ed off with this
any more thoughts anyone
when you between the fuse and 12v cable you mean from the battery to the fuseholder ?
At the fuseholder itself. there was an intermittant connection between the fuse holder and the cable itself.
I think the problem may be with the pre-outs.
Some amps just can't handle anything over more than about 2.5V. If the pre-out level is selectable, try backing it off to a lower setting.
If you can't do that, can you run the system from another h/u or bodge some cables so you can run off an MP3 player or walkman etc. as a test?
Other than that, try checking all of the connections between the battery and the amp. Especially the hex screws on the fuse holder etc. They do seem to like coming loose... or looser than ideal over time.
If you've got a voltmeter, check the voltage across the amps +/- terminals and monitor it when you turn it up.
J.
been back to shop not much help i've changed the remote wire to the one that came with the wiring kit i have now been out and bought proper 8 gauge and fuseholder but it has been raining all day so i aint had chance to fit it all so i am sitting here waiting for the rain to stop i now have another problem after loosening the boot catch i have aa light on the dash saying the door is open
i dont know why i bother
and i've bloody chicken pox on top of this
problem solved my fault i'm thick as **** i connected the rca to my aux input on the headunit oh well at least i now have 8 gauge wiring sounds good too standard speakers bearing up well although i have set them on the crossover on the headunit so they ar'nt working so hard thanks for all your help mock me if your so desire as i deserve it
surprised it worked at all tbh :confused:
at least its fixed :)
  2. Tap Permissions โ†’ Notifications.
