Potential Group buy: Custom Exhaust, anyone?
As you may know that an exhaust for an S3 is from between £2k - £4k depending on which brand.  I've heard that the Milltek system for the VW Arteon is similar, however will need modifications to fit.
I've been speaking to DKU Performance based in Walsall who are custom exhaust/pipework fabricators and I asked if he could build an exhaust which is fairly quiet, non droing and resonating! (well, I kind of challenged him if he could! :biggrin:)
He's prepared to do a groupbuy with a minimum order of 5 as per the challenge, he will design a spec based on the requirement.
He can do a turbo back, cat- back or 3.5" turbo back, retaining valve control. Depending on the final spec will be between £1200 - £1600 fitted.
So please let me know if anyone is interested!
Edited by Awesam
Added additional comment
Dropped the car off this morning for the work to commence.
cant wait until Thursday!
Wow, two central resonators! it has to be quiet :thumbup:
how much space is there between the "rear" central resonator and the drive shaft?
Dont know! lol I'll find out when i go pick it tomorrow.
Yeah thought to have 2 as Im running the trackslag 4" decat.  The rear resonator seems similar to one you have?
Very similar!
At idle it's like stock sound, isn't it?
How does it sound while driving?
Yes very similar sound, the decat does increase the sound slightly.
Sound increases at 3000 rpm.  Did you experience any bottlenecks to get the power out?
Not at all, apart from having no double injection.
However, I believe that I will replace my spark plugs (NGK R7438-8) because every now and then I have problems with ignition on one cylinder. I will talk about it with my tuner.
I'm going for NGK R7438-9 as I was initially going for the R7437-9 but was told they are like stock!
The R7438-9 are best suit for cars for over 500bhp.
