Smartlink
Hello, a pleasure to introduce myself, my name is David and I write from Spain. I have a problem with the Smartlink of my Fabia 1.0 Ambition (Bolero). And is that when I click on the Smartlink option, the system is "thinking" and cannot move forward, so it does not connect to my device. I have tried a system reset, but I can't get it to work. Any idea or solution? Thanks.
VIN of your Fabia?
TMBEB6NJ5JZ110799
Not my specialty, and I may have misunderstood the problem, but I suspect your "infotainment" is stuck because no phone is connected via USB.
Attached are a couple of likely pages from a 2018 Fabia owners guide - both apple and android start with
Connection set-up
› Switch on the ignition.
› Switch on the Infotainment system.
› Switch on the external device.
› Connect the external device to the USB input using a cable »
Thank you,
I Will try without any Bluetooth function on the car and the phone, only without cable.
I always try with cable but with Bluetooth connected to the car.
Bad news - your unit is 5Q0035819C, such units do not support SmartLink (although you might have such icon available in touch screen menu).
Checking PQ codes of your car just confirms it:
To get SMartLink active you must have glove box unit replaced :(
Oh ****!
thanks for the reply anyway. I can't understand why the icon to access the menu is there, if that's not possible, but at least I already know that I don't have to keep trying. Thanks!
Make sure you use the original USB cable! As I had a problem with mine.
The original phone cable?
  • 3 years later...
replied in your original thread
