Battery status on infotainment screen
Does anyone know if it is possible to display the battery status, range etc on the infotainment screen? The readout on the Dash is so small as to be useless (and I have good eyesight) and sadly I didn't spec the HUD! I doubt anyone who need reading glasses would be able to even see much of the Dash info.
Our Peugot e208 has the ability to display the battery status on the infotainment so it seems odd that the Enyaq does not allow for this.
Also is it possible to customise the info shown on the Dash readout? Again the Peugeot allows for a number of preset displays and a custom option. I've had a good dig into the settings but cannot seem to find an option for this.
Thanks.
Select vehicle screen, then charging in the top right corner and you get this.
But that doesn't give me any range info - it'd just be good if the Dash info could be replicated on the larger screen.
It doesn’t, but if you know for example,  that 100% is 200 miles, then every 10% of loss is 20 miles less. The data screen will also give you info on miles driven since start or charge.
The short answer to your question is that it doesn’t do what you’d like it to.
Edited by classic
