Replacement boot release switch for Superb Estate
Hello Folks,
The switch / handle / release button on the rear tail gate has gone from intermittently not working to just not working. The boot opens fine on the fob, so I know the lock is fine.
I need to order a new switch (can anyone confirm the number for me?) and I need to remove the interior trim panels. When I tried this previously; I couldn't get the lower section to release the clips by the window (managed to get it off by the lock). Is there any tips for removing this without breaking it?
I've done this recently as part of an RVC install. Getting the plastic panel off at the window is a real pain. The only screw is the one holding the rubber pull strap, after that it's all those v-shaped trim clips. They're mounted on standoffs on the plastic as well, so it's difficult to get decent leverage on them. Perseverance and patience (and having some decent epoxy handy for repairs) is the order of the day. Not sure of the part number offhand, but a trawl through www.oemepc.com should get you sorted.
Thanks @chimaera
I took the panel off today to get a look at the part number (3T0 827 566 C for those that may need it in the future). After I got the ones around the bottom (and side under the window) the 4 central ones came away in one go
Turns out it snapped a pin in the connector and so wasn't making connection. I've checked the car side of the harness with a paperclip and that worked as expected.
New switch ordered from eBay for £12. I've left the panel off though to make life easier for when it arrives!
