DRL option in Light settings
Hi,
I'm trying to enable the menu option for daytime running light (useful to conserve energy when coding)
When I go into Central electrics 09 click security access, enter code followed by adaptions I don't see the option:
(2)-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich
I have L&K model from 2016 so assume I have the hardware, I have auto beam and rain sensor. What am I missing?
I am using obdeleven
That's exactly wat I did - and the DRL menu is enabled.
Mine is MY17 though.
I do know things changed between MY16 and MY17.
For example MY17 onwards no longer has module 55 headlights.  Instead this is now under module 4B multi-function.
Likewise, from MY17 onwards, there is no long coding anymore - it all via adaptations.
Maybe with urs, being an MY16, it needs to be done via the long coding.
Edited by JR RS
It's funny because I just enabled traffic sign recognition and had to follow the 17my procedure and not the 16my one..
Anyone know what the long coding byte / bit is ?
Edited by mfizz
So I think what I've worked out is that under adaptions, obdeleven have split it further in sub menus... Under which you'll find options to activate / deactivate.
Just need to find the right one under adaptions to open up the menu that will contain it. ( I hope)
Going to answer my own question now..I found it under
Aussenlicht_Front
I think vcds just allows you to search everything obdeleven only has the search functionality at the high level.
Using nextgen obdeleven even said function not available had to quit and try again for it to work.
I was meant to say the changes were specific to modules 09, 4B and 55 only.
TSR has nothing to do with these modules.
Hence there is no difference in enabling TSR between MY16 & MY17.
To enable TSR, u need to make changes in 5F, A5, and 17.
1872949206_Screenshot_20210830-0810442.thumb.png.9fd29ce6c4d9066a2c70cabffaa0a621.png
Edited by JR RS
Perhaps I'm mistaken.. I thought from 16(or 15) to 17my for tsr, it changed from byte 1 to byte 16 (according to gizmos's thread) I extended that 17my quality to all the other modules.
None the less, I managed to get to the desired option it was just hidden away under another.
On a separate note, that's a nice looking document your got there is that your own or is it available somewhere?
i made that doc myself, based on the Tried and Tested VCDS codes for Superb, and other OBDeleven discussions.
VCDS Coding v1.1 - Superb MY17 - JR.pdf
