update of Columbus mapping
Don't copy the folder to the SD card, just the relevant contents.
thanks merlinman any idea what the contents files should look like ??
Been following this and similar threads since I got my Karoq in March and the update system is as clear as mud to me, I along with others thought updates for maps would be done over air ?,  I had some sort of update a few months ago which didn't seem to change anything, this morning I put my VIN into the portal and it shows a map update sitting there, when I scroll down the page it lists the MIB 3 when I click on that it tells me to download update onto a key etc, does this mean OTA updates are no longer working and we need to download them manually??
am not sure what an OTA update is??.
I did finally get my 'Skoda' SD card to upload successfully. The download from the portal via my laptop took about 6 hours just for the simple European update. The key thing is when you 'unzip' the file you end up with it in a 'folder' and you need to take the files out of the folder before you tranfer them across from your laptop download to your Skoda SD Card. I hope that helps.
The lack of support from Skoda and their agents (in my case Bristol Street Motors) for this defies belief - it wouldnt be acceptable in any other branch of commerce - not sure if other car suppliers are any better or not mind ?? Cheers
OTA = over the air, which is the way MIB3 systems are supposed to update via a built in Sim
