Rear window jet not working
Hi.Been struggling to adress an issue with my rear window jet not working.Doesnt spray anything removed plastic trim in booth to acces all area there no leaks or any damage there.Maybe someone had same issue and know answer.Thanks in advance
Hi, Is the pump working can you hear it?. could be something simple like a blocked jet. If you have a wire brush pull one of the strands out with a pair of pliers and use it to poke the jet while someone works the wiper. Not too Sure about VRS my mk2 is the one that has the water go through the motor I had to change my motor as it had rusted and that was blocking the jet.
Hi.Yeah pump seems to be working.Yeah will try to unblock it then.Thanks
