vacuum or overpressure
HI, I recently bought a 2002 Octavia vRS. The car is amazing but has an issue which worries me. Everytime I open the gas cap it hisses and I hear the tank popping as it goes back into it's shape. This happened a few times and i started driving with the gas cap a little bit opened. My suspicion is the evap system, but i'm not sure. I don't want to change the parts which are completly fine.  I am not a native English speaker, if you haven't noticed already.
That's a vacuum. There is supposed to be a mechanism to relieve the tank so that it doesn't go into vacuum if you drive a distance before opening the tank. I have heard of a few cases where this effect has distorted the fuel tank. Do you have the standard tank cap or a replacement?
That was my first thought. I bought a replacement but it does the same thing.
I can't feel any problem while driving. It pulls and revs high nicely. The fuel consumption is normal. When reading the codes nothing shows up.
OK, the last time I encountered this issue, it was with a replacement unventilated tank cap. You might well fix it by drilling a 1/16" hole in the cap.
There is nothing in this issue that will actually throw a fault code until you get a situation where the tank is actually imploding causing fuel starvation.
Edited by KenONeill
Isn't there a vent hose through a charcoal cannister filter?
