Welcome to folding RobClubley & Gillywibble
- there's only one fairy in these there woods you know......
So glad you said that ;)
I've completed two WU's so far and just got the second PC running.
When I try to add -forceSSE I get an error message
Folding@Home
Folding@Home Version 5.03
Usage: fah5 [-option1] [-option2] ...
Options: -config Configure user information
-configonly Configure user information, then exit
-help Dispaly this usage screen
-queueinfo Get information on queued work units
-delete x Delete item #x from work queue
-send x Send result #x to server then exit. Use x=all to send all results
-verbosity x Sets the output level, from 1 to 9 (max). Default: 3
-pause Pause after finishing & trying to send current unit
-oneunit Exit after completing one unit
-local Use configuration files from local directory. Default: Registry
-forceasm Force core assembly optimizations to be used if available
-advmethods Use new advanced scientific cores and/or work units if available
Please note the above recognized flags for when you start Folding@Home again.
OK
This suggests that -forceSSE is not an option.
Any clues :confused:
Cheers,
Jon :thumbup:
Hi all, I think I have just joined the team, but not sure:rolleyes: , dont know how to check, so if someone spots Superb1 in there, could you please let me know:thumbup:
Bryan
Hi all' date=' I think I have just joined the team, but not sure:rolleyes: , dont know how to check, so if someone spots Superb1 in there, could you please let me know:thumbup:
Bryan[/quote']
If you check the file called "unitinfo" it gives progress on your current workings.... I suspect this is your first one now, so once it reacheds 100%, and then goes back to 0% to start the new unit, it will be about 6 to 9 hours before you appear on the league in the link in the first post. :)
Obviously the more machines working, the quicker it will get on there and the quicker your charge up the leaderboard. :cool:
How long is normal to complete 1 WU (whatever 1 of those are) lol
Depends on the particular protein fold. Some take a day, others take months.
Yeah I bought an old server to run my email and stuff and have an Athlon 2500 doing nothing much. Not a great deal of CPU power but everything helps!
I ran it at 100% CPU for 2 days and it overheated and shut down - doh! So it's at 60% now and doing well.
Thats the ultimate over heating solution - run it slower or add more cooling. :) I bet it would be OK on 70% though. ;) :P
Pah, folding is for............................
someone passionate about origami? :D
Your team ranks 12 Jason, how many's that out of?
Ok, 1 WU done, it was 500 frames:rolleyes: , next 1 started, 5,000 frames:eek: :eek: . That will have my PC going for next 12 mths:thumbdwn: . What happens why l need to restart my PC:confused: :confused:
The folding program saves itself every so often, so shouldn't be a problem. On reboot it will continue where it left off.
Jon.
That bit on the left is my rank in the team - 12 out of 105 odd now, but many are inactive. The team is ranked 153 out of 40 odd thousand teams. :cool:
Blimey, you lot are folding faster than Superman on laundry day :eek:
It's been on 80% for a few days now :thumbup:
