Fuel filter housing screws torque
I am about to change my diesel fuel filter. The 5 x T25 screws should be tightened to 5nm. How critical is it that a torque wrench is used? If I made a mental note of how tight they feel when removing them, and then try to get them the same when reassembling, wouldn't that likely be good enough?
There is a danger that if you over do the tightness you will strip out the threads. The fuel filter housing is aluminium bodied so sure, make a mental note but there is a higher risk you will overtighten.
5nm is a 'light' pinch up tightness, if you are concerned, then use some semi-permanent loktite to keep the screws in place.
