Just taken delivery. First two questions.
Hi, Just picked up our Edition this morning. A couple of things I can find out about.
1; I knew about the usb c sockets, and I have read on the forum that Skod provide usb c to usb adaptors. I don't seem to have any. Are they likely to be hidden around the car?
2; I have paired up my phone via bluetooth, but someone called Alexandru has previously paired an S10 Galaxy. Try as I might, I cannot find how to delete it. I'm assuming it's a Columbus system.Anyone able to help?
A third issue. The mirrors are supposed to dip in reverse. Dipping is activated in the menu, but the mirrors are not dipping. Am I missing something, or is it back to the dealer?
Only the left mirror dips and the mirror controller on the door has to be turned to L .
I didn't get any USB-C adapters with my car, but they're readily available elsewhere (Tesco, Amazon etc) and then you can choose the size and type you want.
I think the Telephone menu in the car will let you delete the other phone pairing, and you may need to ensure that the Car menu has the dipping mirror setting enabled.
Chris
Thanks very much, one issue solved, 2 to go. I have a potential issue with the satnav, I live in Dorset, and on the journey home the satnav showed the correct area map, but for some odd reason, it displayed the position of 2 railway stations in Norfolk! I usually use Google Maps, but I can't connect my phone as I don't have any usb c cables. Some on order.
You'll find the maps will update themselves online when updates are available, but there will always be some odd glitches. I suspect the map tiles in mine every now and again don't have the UK flag set as speed limits suddenly show as 45 or 90 (ie the UK limit in Kph). And coming home on Wednesday it suddenly showed a new car dealership where there wasn't one.
Chris
You should be able to connect wirelessly since from 2021 Karoqs come with MIB 3 which has wireless Apple Carplay and Android Auto support.
Unfortunately my phone is too old to connect wirelessly.
