Mk1 fabia vrs throttle body
Hi, my throttle body is playing up and putting the engine light on,  I've found one on ebay with the same part number as mine but it has an M at the end and mine has an G
038 129 063 G
038 129 063 M
does anyone know what this means and will it still fit my fabia VRS?
Ok thanks so it should be ok then?
  • Sponsor
Yes
Have you checked for wiring damage near the connector plug?
Cheers mate.👍
No, is this a common fault then?  Why would the wire be damaged?
  • Sponsor
Wiring tends to be as thin as it possibly can be, and gets heat-cycled and vibrated whenever the engine is run. It's also now 15 years old. Careless workmanship during maintenance or disconnection without understanding of the latch mechanism are also risk factors.
Always worth a quick look in the vicinity of the connector cable entry.
