D3S bulbs
Hi!
in the near future i will change my bulbs because one of them has started to flicker.I saw many reviews on yt but i couldn’t decide what bulbs should i buy. Any recommandations? thank you !
@varaderoguy2015 with bi-xenon, yes.
those don’t seem so good. i mean they are expensive, yes, but don’t know what to say. from yt videos, they don’t seem to be so good. this is one option, 2nd option is osram nightbraker laser xenarc.
any recommandations?
OSRAM Xenarc Laser Nightbraker D3S
i’ve read a lot of reviews about those 2 ( osram xenarc laser and xtreme vision gen 2 ) and people say that the  xtreme vision will be brighter and stronger after 30h or 100h ( or something ). thoughts about this ? or about osram ?
I hear the Nightbreaker units are good, these will be my choice when it comes to changing, despite the short life span.
@MATT0693nightbreaker seems to be so yellow.
what about osram cool blue intense next gen ?
Got these last year were a bit cheaper for BlackFriday at £123.48. I like them, replaced the phillips ones from factory. Can't think there is a lot of difference between them when new and run in.
https://www.amazon.co.uk/gp/product/B07FY78JBQ
@FUBARcan u show me some photos ? i saw many reviews where people say that they are yellowish. thank you 🙏🏽
If you click on the amazon link above there are 42,000 reviews and over 100 customer submitted pics :thumbup:
El 25/11/2021 a las 18:30, cata032 dijo:
@ MATT0693Nightbreaker parece ser tan amarillo.
¿Qué pasa con Osram Cool Blue Intensity Next Gen?
I am also among the CBI new gen or the Nightbreaker ...
If it was me I would just fit oe bulbs. No point fitting brighter bulbs if they don't last anywhere near as long and especially as they aren't cheap.
Im a cheap skate Just fitted these from Autopark  Xenon Bulbs 16,50 the pair & 3 year guarantee. And a very notable difference from the old ones
8 hours ago, Ecomatt said:
Si fuera yo, solo colocaría bombillas oe. No tiene sentido colocar bombillas más brillantes si no duran tanto y especialmente porque no son baratas.
Before I used to spend it on going out at night out and now it doesn't hurt to spend 150 euros on some light bulbs or on anything for my new hobby which is the Superb.
6 hours ago, Cap44 said:
Soy un patín barato Acabo de instalar estos de Autopark Xenon Bulbs 16,50 el par y 3 años de garantía. Y una diferencia muy notable con los antiguos.
Could you put a link?  Thank you!!
125009982430        now £13-79 for 2 bulbs   Autopark
4500K is the original white bulb, these are 4800K so would be little or no difference.  definitely not yellow
Sorry Johnny says on the box 6000K. What ever they are they are about 50% better than the Philips candles I took out. Even the G/F  Focus had better lights than the VRS before I changed the bulbs .  No brainer for £13.79 posted
Replaced 5y old working OEM Philips with aftermarket OSRAM NB Laser, and it is a lot brighter.
You can see clearly the difference between old and new, no description needed which is which.
