Amundsen DAB Issues
Hi
Having searched the forum I’ve been unable to find anything that addresses my problem.  I have a 2014 plate Skoda Yeti Greenline 1.6TDi Exclusive fitted with an Amundsen Radio/Sat Nav.  Recently I’ve been finding that the DAB reception has been dropping out a lot more than usual, this tends to be intermittent with no real pattern to it. The radio is set to default to the equivalent FM signal if there is one and this is what has been happening.  I’ve had the radio out to look at the connections and cabling at the back but can see no obvious problems.  When I long press the settings button in radio mode I pull up the service menu, this consists of 4 sub menus: FM Monitor, AM Monitor, DAB Monitor and Versions.  When selecting the FM and AM Monitors they both show Ant 1 on, however the DAB Monitor shows Ant 1 off but with a strong signal (green bar) and GOOD in the right hand top corner.  Not sure where to look now, replacing the antennae base is an expensive option and it might not be that, as is replacing the head unit.  I’ve read on this forum that there are 2 antennae’s for the DAB with one situated in the rear screen heater element.  There is no mention of a second antennae in the service menu.  Was wondering if there is a pre amp somewhere for the DAB which may be faulty causing it to show no antennae but still giving a strong signal?  Clutching at straws here but has anyone any ideas? I’ve even tried rebooting the radio by removing the fuse and leaving it for 10 minutes but still no luck and, of course, deleting my presets and rescanning. When I tried retuning the DAB, I got a list of stations (all BBC, most national (notable exception is Planet Rock!!!) and most local but there is the crossed out antenna sign against all of them. However, when I set my preselects again they appear as DAB stations and in fact if I select them they will play for a varying length of time in DAB mode until switching (where available) to the FM channel. I live just west of Worcester on the Hereford/Worcester border, I've had no previous issues with DAB reception up until a couple of weeks ago (even got Planet Rock).
If anyone could shed any light on the DAB set up from Antennae to radio it might JUST shed some light on the potential cause of the problem. I just can't understand if the system is telling me that the DAB antennae is off (and there appears to be no way to turn it on) how is it receiving information on the DAB stations to be able to list them and is able to play on DAB for varying lengths of time? I'm a very confused Yeti owner!!!! Thanks in advance
Just checked reception on my DAB radio in the house and all DAB stations are playing fine so no transmission issues.
Hi Muttontop
"I’ve read on this forum that there are 2 antennae’s for the DAB with one situated in the rear screen heater element"
As far as I know, the two antenna (diversity) setup is only applicable to FM.  The technical characteristics of DAB make it resistant to the effects of multipath reception (lots of reflected radio signals in the reception area) so only one antenna is necessary.
I don't have any technical detail on the Yeti DAB antenna, but imagine it is incorporated in the roof-mount unit, different parts of which serve AM, FM, DAB and sometimes GPS. It will have a dedicated DAB coaxial cable between head unit and antenna, and there may be a pre-amplifier in the antenna base which will need a 12 volt feed at fairly low current.  Again, this feed may share the antenna cable or be supplied separately.  If it comes down the antenna cable, it may be necessary for the head unit to be programmed to provide it, but I would expect this to be the factory default setting anyway and it won't come and go.
If the DAB antenna is faulty/disconnected, or if any associated pre-amplifier is not powered, you are unlikely to get any signal strength indication or any reception at all.
There have been past discussions on this forum on the roof mount antenna and its cabling.  If water gets in, parts may fail but this may only affect some bands.
DAB reception can be a little patchy, and the fallback to FM is supposed to tide you through a small blackspot before reverting to DAB.  It sounds as though the head unit is managing to switch to FM, but is failing switch back again for some reason.
Hi all
Further to this problem does anyone know where in the boot lid the aerial antenna amplifier (part number 5L6035577A) is located, and, more importantly, how to get to it!!!  I thought I would try this first as a) it is cheaper and b) I thought it would be easier to get to (although having tried to remove some of the inner covers on the boot lid I'm not so sure now).
