A question born from sheer boredom ...
I dropped on a friend today who is in the process of modding a T5 to T5.1 spec.
For those not into VW Transporters, this involves fitting the front end of a T5 facelift, to an older model.
As my 2012 is a Cat C and had good front end damage before being repaired it got me wondering whether anyone fitted the front end of a facelift Yeti to an original ?
Definitely agree that the pre-facelift has more character ( I have 2 :) )
And of course the Yeti, in both its iterations, enjoys the company of the Morris Minor, the VW Beetle, the Robin Reliant, the classic Mini, the E-type Jaguar and a few others you can probably name (probably from some time back) where when you see one you don't think "Is that a Yeti or one of those that looks like it?". (I should also add the Ford Anglia as I grew up with a couple of these and the Ford Capri that, as a young Anglia owner I aspired to. No-one aspired to a Ford Cortina).
Unless it was a LOTUS!!
Agreed in a way - I had a mkII Capri 2.0 ghia  which was the affordable in car to have at the time.  I also had a mkIV Cortina when I started travelling a lot of a similar vintage that was vastly superior to drive. The Capri (even later ones) had cart leaf springs at the rear - horrible things whereas the mkIII & mkIV Cortina had coil springs (still had a live rear axle though) . The Cortina also had double wishbone front suspension.  Cortina was also way more refined. HOWEVER back in the day the Capri was cool and the Cortina was just a reps car.
If I could go back in time I would have mothballed both of them - I'd be richer now!!
Edited by bigjohn
