Returning to Briskoda - Superb Estate
Hello,
Used to be here many years ago having owned Estelles, Favorits, Felicia and Fabia and now about to return to the fold.
Looking at buying a diesel Superb estate of the 2010 - 2015 model as I need the boot space so what should I be looking for in terms of any problems?
Hello GOUK :hi:
It might be worth doing some homework around oil pump issues on a certain 2.0 diesel model, which was a bit of a lemon.  Might be earlier than the age range you're looking at, but worth being aware of.  The pump has a hex drive shaft, which rounds with wear, and then fails, usually catastrophically.
A good rummage around the Mk2 sub forum should also provide you with useful reading.
Gaz
https://www.audi-sport.net/xf/threads/worn-oil-pump-hex-drive-shaft-on-my09-2-0-tdi.274775/
