Clunk/clicking noise with fluctuation in RPM
Since i received my octavia 8 model 2021 and i have been having this issue :
when im speeding and pass the 30-35km/h speed there are 2 clicking sounds and the rpm drops from 2000 to 1000 suddenly. And the sound occurs when the rpm is dropping. , the dealership are telling me nothings wrong but im pretty sure this is not normal.
i have added a video as well
please help, tell me what should i be checking
thank you
Looks like you have the DSG gearbox; what happens if you put it in S mode? This should make the gear change at higher RPM as well as display the selected gear (e.g. S1, S2, …, S7)
Could also try using the DSG paddles to do a manual gear shift, might help determine at which (if any) gear change the noise occurs.
I haven't tried that actually i usually drive on D, i will try that and tell you
thanks for the reply
@Esto
Welcome.
Maybe say what engine your car has.
1.4 TSI
automatic - 8 speeds
petrol
@Esto
So not a DSG.
Where are you, Australia?
Are these just 1.4 TSI's without ACT?  (Active Cylinder Technology).    So no Cylinder deactivation.
If the Dealership employee says all is as should be do they have another identical model to let you drive so that you can compare?
Edited by roottoot
Not sure about the ACT but i will ask.
they actually offered me to try another car but  i declined, ill do that next time
@Esto  are you in Australia?  I have watched vids of VW cars in the USA and the Karoq in Australia with the 1.4 TSI and 8 speed auto and have not seen mention of ACT.
No im in egypt
  • 3 years later...
@Esto could you solve the ? I have the exact same thing with my vRS diesel.
