Octavia 2 Hatchback struts
Mine are getting weepy and failing i did read a long while ago there are Vauxhall ones very similar in length but a stronger Nm force than the Skoda items these would be ideal for me making it easier to open being disabled , any help would be greatly appreciated .
Paul
I replaced mine a few years ago and remember finding more than a few internet sites offering replacement struts for Skodas. Beware stronger struts as they will also increase the pull down force as "The Boss" made clear to me!
Paul
As you can see in the autodoc link below, there are two types. 440N and 460N for the Octavia MK2 hatchback. The 460N is when you have a rear wiper as it add a little weight to the tailgate and therefore needs a little extra force. Stabilus are OEM quality.
The "N" in 440N and 460N means Newtons, which is a measurement of force. 1kg is about 10N, so these give about 44kg and 46kg of force respectively.
They both have a length of 584mm, and a stroke of 240mm.
Using struts from the wrong car, is likely to give you the wrong force, the wrong length, and the wrong stroke.
If you make a note of the part number, you can probably find them on ebay and amazon, etc.
You can see how easy they are to fit by watching a video on youtube. Or just examine the new ones carefully, to understand what you have to do to get them to clip on and off.
Stabilus Gas Tailgate Struts
https://www.autodoc.co.uk/spares-search?keyword=gas+strut&sort_categories[0]=219&supplier[1]=126
Here's one I've seen on ebay priced at £26 for two (including the 10%)
https://www.ebay.co.uk/itm/165076859173?hash=item266f58f925:g:2OQAAOSwFQBdCQor
Edited by Carlston
I recently replaced the ones on my estate tailgate.  I thought they were the same as the original, but they are strong enough to fling the tailgate up against it's stops, so now I have to restrain it whenever I open it.
