Can the siren be deactivated??
Hi all,
I am new to the site, I've just purchased a skoda from a friend. I have an issue with the car.
The unlock button isn't work so I have to open the car with the key, not the end of the world for me however I leave for work at 5am, as soon as you unlock and open the door the alarm goes off. I cannot have this at 5am.
Is it possible to remove a fuse etc to stop the siren on the alarm going off?
My other car is a volvo and we had an issue with the alarm going randomly however easy fix was to remove the fuse for the siren. Same with leaving my dogs in the car the volvo has a deactivate button for movement the skoda doesn't so 2 seconds in the shop today and alarm going off.
I just need to switch the siren off not remove alarm altogether. Removing volvo fuse allows the lights to still flash just not the alarm screaming.
Can anyone help, please.
Ps. Its a skoda fabia 2 2010.
My old MK2 fuse went on the car if I remember correctly the fuse you can try to disabke the siren is in the top row of the fuse box it's a 15 amp number 54 its the 5th in from the left side of the fuse bnox
Just now, Murdockman said:
My old MK2 fuse went on the car if I remember correctly the fuse you can try to disabe the siren is in the top row of the fuse box it's a 15 amp number 54 its the 5th in from the left side of the fuse bnox
Thank you. I will give this a try. I thought I had the right fuse but couldn't have been because it still rang, not as loud but did still ring.
