Error PO68B
hi i need some help/info, my cooling fan stays on which inturn drains the battery, happens at least once a week, have to jumpstart vehicle with leads to get it going again, error code is PO68B, any ideas what it could be as have been advised that need a new cooling fan by a local mechanic,i know its something to do with the electrics???? any ideas what it could be and how much it would be
Most likely its the relay,belive its the J271, it should be located in the engine bay!
thanks for the reply, any ideads of cost?
Not sure on cost, depends on country, to be sure its the relay, check resistance between pins 85 and 86, if its very high ressistance its the relay, should be around 85 ohms if i remember correctly..
As for the price of the relay, usually around 10 eur!
