yeti abs coding required
can anyone help me with getting the long code for abs, previous unit died could not extract code....Scott
This was from an Autoscan on my 170 MY2013. Not sure if the same since the 170 has the larger front discs.
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BL    HW: 1K0 907 379 BL
   Component: ESP MK60EC1   H31 0152
   Revision: 00H31001
   Coding: 963F600E09270103691206E5901D808A310000
   Shop #: WSC 33361 790 00064
   VCID: 7DA7FA152DF8979FA21-8028
No fault code found.
I got a Ross- Tech feed with a 933...310000 code was accepted I still have to complete ESP function test to see if the abs light cancels ,waiting for evening for carpark clearance.
the hill hold function has not started to work either ? hopefully all is linked to function test.
completed ESP function test all warning lights are cancelled and no fault codes.
Holy Moly what a mission.
Thanks for all the input and help guys😃
