LED Matrix Headlights query
I've had my facelifted Sportline a couple of days now, and since I have yet to drive it in the dark, I have a query regarding the LED Matrix headlights.  I know how to activate the Auto Light Assist (light switch to Auto, push lighting stalk forward, and the headlight symbol with "A" appears on instrument panel).  What I want to know is whether the car remembers this setting when the ignition is off, or does it have to be reset every time the car is started.  I hope someone can help with the answer.
If it follows the normal VAG convention then it needs activating with each journey. That's the way on my Superb too.
Thanks for the speedy reply, and I can cope with that.
You need to be able to select and override this option as required.
eg it does not put on main beam at low speed but I often need it on on narrow country lanes so override to main beam on
The LED Matrix lights are pretty good. My wife can't believe the difference at night between the Karoq & her old Fiat 500 which I think had candles for headlights.
