Vacuum line diagram on mk2 Vrs 2.0 tsi
Hi everyone.Does anyone have handy vacuum line diagram?Suspecting small vacuum leak and been thinking of replacing all  vacuum hoses as inspecting them did see any failure but cant think of anything else what could cause engine running a bit rough on idle.Thanks
Pinch lines to eliminate suspects, possible spark plug/coil issue.
In past 2000 miles I have changed:
Spark plugs
Coils
Cam fallower
High fuel pressure sensor
Intake valve clean/injectors
Cam shaft sensor.Moast of those parts had to be changed sooner or later as it has rolled over 100k and plugs for example have been replaced 40k ago.Fuel pressure and cam shaft sensor was a blind shot just in case it changes anything but no it didnt.Taking to garage is pointless been in 3 and no one can tell anything
