EGR duty circle good or bad readings?
Hi Folks
Today just check my 1.9 BLT with VCDS and got a few readings from EGR , I was suspicious cause after a ride when I leave the car a on idle the EGR is closing after 1-1.5 minutes , so just check it and it says
attached the readings
is it good or not really ?  if not what causes.   also when it is closed. MAF reading is a bit out of the normal range ?
Thank you
Edited by vonweiser
