Oil Leak Near Turbo - Also squeaking noise when gear shift in 2000 Above RPM
It is possible there is no real problem other than excessive gases being passed by the PCV on the camshaft cover or the relevant o-rings are worn.
Read up on it and how it can fail.
In the meantime you can disconnect the intercooler inlet/outlet pipes and drain any build up or remove all the pipework and clean them, ensuring the sealing o-rings are in serviceable condition when you refit everything.
