Amundsen head unit glitches -17 plate Yeti Outdoor
Hi
The head unit on my Yeti has started playing up over the last few days after 5 years of faultless service. The touch screen will freeze or go unresponsive (as will the function buttons). The sat nav display will continue to work if I am on the standard navigation and apple car play, but you are unable to change any of the settings.  If I reboot the system by holding down the buttons it will reset itself and work again as normal before freezing again later for no obvious reason.
Any ideas or others with a similar experience?
1 hour ago, clarky2 said:
Hi
Yes very common.
You could try.
https://www.satnavsystems.com/diagnostics-repairs/
Thanks for your reply. I will check them out.
I used a guy called Ant Richardson, who was recommended in another thread - I'd definitely recommend him and only charged £200 for a new screen
His number is 07979 723977
