Help required for Engine fault
Hi, I need some help with my superb 2009 tdi cr 170.
It had an issue where it would start from cold every time. But once warm it would take about 5 attempts to start. The glow plug lamp would come on and engine would not fire. I did a vcds which said bank 1 out of correlation.
I then changed the cam belt, the timing looked okay and the new timing positions look fine with the new belt on. At the same time I replaced the cam sensor as it is located behind the timing belt.
Since then it has only started once, and never again. Now I’m a bit stumped.
The vcds read out I get is below which is the same as before. Any suggestions I would appreciate. I’m pondering if I’ve got some broken wires in the working harness?
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 QH    HW: 03L 906 022 GA
   Component: R4 2.0l TDI G000SG  9978
   Revision: 13H01---    Serial number:
   Coding: 0201072
   Shop #: WSC 91750 042 00000
   VCID: 7BF54BD03AC859579A-802E
   VINID: 91D4925870E405124000920820ABEFB59A
1 Fault Found:
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
               P0016 - 000 - Incorrect Correlation
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 63
                    Reset counter: 255
                    Mileage: 289664 km
                    Time Indication: 0
                    Date: 2016.11.25
                    Time: 18:14:53
             Freeze Frame:
                    RPM: 1058 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.86 V
                    Idle Stabilization: -2.7°KW
                    RPM: 536 /min
                    (no units): 33.0
Edited by Nackuk
When you did the timing belt did you use the correct lockdown tools and procedure?
Yep, got the timing tool set and Skoda manual to follow. All seams okay. Wound it round several times to recheck before putting the covers on.
