Number Plate LEDs
Can anyone recommend an LED number plate light complete, not just bulb.
I've tried two, which are supposed to be error free, but everytime I put the lights on it comes up, check number plate light.
Any ideas. Thanks.
Why not use genuine ones and get the car coded to suit?
I believe the part number is 000052110 :)
If you can't get the genuine LED units coded out Kufatec do wiring adaptors to provide resistance to stop error lights popping up.
  • 4 weeks later...
I should add I bought genuine Skoda ones from Horton Skoda at £12 a piece. This was cheaper than places on eBay which were charging £15+ each. I plan to get them activated using VCDS soon.
  • 4 months later...
Hi,
Did you get these activated with VCDS?
I plan to do this but need to know it works.
Thanks.
5 hours ago, Besters said:
Hi,
Thanks.
I paid someone to activate it through VCDS but OBD11 is another option.
I have VCDS, just need to figure out the coding.
Find the leuchte channel for number plate lights in the bcm 09, simply adjust lasttyp to ‘LED general’ and you won’t get any more errors
More info here too:
Thanks for the info 👍
There is a link to all the how to guides on VCDS on this part of the forum, should be one of the pinned posts above.
Thanks 😊
I bought the genuine Skoda LED lights and have come to do the coding but it's not accepting the security access code 31347.
Anyone know what the problem is?
Thanks.
