Monte Front Brakes
4 hours ago, D15VRS said:
Would the knuckles from a mk2 vrs a monte? The shock absorbers will most likely be the same, the only thing I'm banging my head against is if the drive shafts are different as dsg and manual.
As you can see in the charts below, the wheel bearing housings for both the Fabia MK1 with 288mm TRW front brakes and the Fabia MK2 with 288mm TRW/ATE front brakes are the same, ie. 6Q0407255S is the left wheel bearing housing and 6Q0407256S is the right wheel bearing housing.
Although the Fabia MK3 uses different OEM part numbers for the wheel bearing housings with 288mm ATE front brakes, these are also interchangeable with earlier Fabia MK1 and Fabia MK2 cars.
Wheel bearing housing for Fabia MK1 with 288mm TRW front brakes
7A 6Q0 407 255 S wheel bearing housing left 1 PR-1LN,1ZH:
AZL,ASZ
(7A) 6Q0 407 256 S wheel bearing housing right 1 PR-1LN,1ZH:
AZL,ASZ
https://skoda.7zap.com/en/cz/fabia/fab/2000-225/4/407-407010/
Wheel bearing housing for early Fabia MK2 with 288mm TRW front brakes
https://skoda.7zap.com/en/cz/fabia/fab/2010-608/4/407-407011/
Wheel bearing housing for late Fabia MK2 with 288mm ATE front brakes
8A 6Q0 407 255 S wheel bearing housing left 1 PR-1ZC,1ZD
(8A) 6Q0 407 256 S wheel bearing housing right 1 PR-1ZC,1ZD
https://skoda.7zap.com/en/cz/fabia/fab/2011-697/4/407-407010/
Wheel bearing housing for Fabia MK3 with 288mm ATE front brakes
8A 6C0 407 255 A wheel bearing housing left 1 PR-1ZC
(8A) 6C0 407 256 A wheel bearing housing right 1 PR-1ZC
https://skoda.7zap.com/en/cz/fabia/fab/2016-797/4/407-407000/
Edited by Carlston
AZL,ASZ
AZL,ASZ
Thank you very much, so unless I am missing something, the housings fit fine, is there a difference in the actual hub between the manual and dsg?
I've checked the Skoda parts catalogue, and there is only one pair of wheel bearing housings. So they will be the same for both manual and DSG.
Left wheel bearing housing 6Q0407255S
https://www.autodoc.co.uk/car-parts/oem/6q0407255s?search=OEN 6Q0407255S
Right wheel bearing housing 6Q0407256S
https://www.autodoc.co.uk/car-parts/oem/6q0407256s?search=OEN 6Q0407256S
When sourcing these 288mm brake parts, it's not just the Fabia MK1 and Fabia MK2 that uses these parts, but all of the following VAG cars:
Audi A1
Seat Cordoba II
Seat Ibiza III
Seat Ibiza IV
Toledo IV
Skoda Fabia MK1
Skoda Fabia MK2
Skoda Fabia MK3
Skoda Rapid
Skoda Roomster
VW Polo MK4
VW Polo MK5
Edited by Carlston
