Amundsen + RNS315 radio
I have an Admundsen + RNS 315 which I took out of my early Yeti that was written off a few years ago. Because of damage to drivers side I was unable to get comple wiring from telephone module under drivers seat and had to cut wiring. I want to put complete radio and module into a non Skoda car but need to know wiring connection of module. . The module VW part number is 3C8 035 730D and has a multi plug with 8 wires as well as a red plug that I think is an aerial plug. Any help with wiring would be appriciated or if anyone knows where I can buy harness
If you can confirm make and year for the donor car, then wiring diagrams can be pulled up.
Thanks for your reply. The radiio has been fitted to pre 70s classic car and is working perfectly ie radio, sat nav and wired up to reversing sensors.Have also fitted upgraded aerial. What i need wiring configuration to install phone module.Robert
I think you missed my question.
What car: Skoda?
Model: Yeti?
Year: 2017?
Need this to locate information to find diagram(s)
Have you got a pic of the rns315? It may have built in Bluetooth anyway that can be activated by vag com.
