Rain closing problem
Hey guys
I enabled rain closing via these instructions
And it works..  But only on front windows.  The back windows and the roof do not respond.  Is there any other VCDS option that I need to tweak?
I do have the setting in the infotainment set to all windows
Does the one touch work on the rear windows using the switches?
If not you need to reset it by winding the windows down and up but hold the switch for a few seconds even after the window is fully up and down.
Edited by PetrolDave
Aaa ok did not know that...  I will test ASAP
Ehat about the paniramic roof?  Does ic fully close with rain close or not? Mine does not
It should do, I've never had a panoramic roof (just a 'normal' sunroof) I expect a similar issue of resetting the end points will be needed, time to RTFM I suspect.
Did the recalibration and still the same thing.. Rear windows and roof don't move and the front windows go up half point.  What manual I coded the feature with the instructions from the top post
Do the pano roof and rear windows now close one touch using the switches? If they do then it's likely a coding/adaptation issue. Please post exactly what changes you made - if you use VCDS then it keeps a log of changes in C:\Ross-Tech\VCDS\Debug as CodingLog.csv and AdpLog.csv which you can open with e.g. Notepad.
Hi sorry for the long delay I had been busy
Here are the logs
AdpLog
Address 01,04L 906 021 EM,channel IDE07903-Adaptation of ash mass,adapted from,0.00 g,to,0.01 g,Tuesday,10,May,2022,21:24:47:00009
Address 01,04L 906 021 EM,channel IDE07903-Adaptation of ash mass,adapted from,0.00 g,to,0.01 g,Tuesday,10,May,2022,21:25:22:00009
Address 09,5Q0 937 086 AA,channel IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,adapted from,not active ,to,active ,Sunday,31,July,2022,15:23:18:00009
Address 09,5Q0 937 086 AA,channel IDE08542-ENG125656-Access control 2-Regenschliessen_art,adapted from,once ,to,Permanent ,Sunday,31,July,2022,15:23:50:00009
Address 09,5Q0 937 086 AA,channel IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,adapted from,not active ,to,active ,Sunday,31,July,2022,15:25:31:00009
Address 09,5Q0 937 086 AA,channel ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,adapted from,not active ,to,Blinken links Dunkelphase ,Sunday,31,July,2022,15:29:43:00009
Address 09,5Q0 937 086 AA,channel ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,adapted from,maximize ,to,minimize ,Sunday,31,July,2022,15:31:10:00009
Address 09,5Q0 937 086 AA,channel ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,adapted from,not active ,to,Blinken rechts Dunkelphase ,Sunday,31,July,2022,15:31:59:00009
Address 09,5Q0 937 086 AA,channel ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,adapted from,maximize ,to,minimize ,Sunday,31,July,2022,15:32:54:00009
Address 09,5Q0 937 086 AA,channel ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,adapted from,127 ,to,0 ,Friday,05,August,2022,16:45:09:00009
Address 09,5Q0 937 086 AA,channel ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,adapted from,127 ,to,0 ,Friday,05,August,2022,16:46:11:00009
Address 09,5Q0 937 086 AA,channel ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,adapted from,127 ,to,0 ,Friday,05,August,2022,16:46:38:00009
Address 09,5Q0 937 086 AA,channel ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,adapted from,maximize ,to,minimize ,Friday,05,August,2022,16:47:30:00009
Address 09,5Q0 937 086 AA,channel ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,adapted from,maximize ,to,minimize ,Friday,05,August,2022,16:48:13:00009
And Here is the CodingLog
Address 08,5E0 907 044 N,recoded (Long Coding),from,02010104002100011005000100101000,to,02010104002100011005004100101000,(73430/031/00063),Sunday,31,July,2022,15:19:26:00009
Address 09-02,5Q0 955 547 ,recoded (Long Coding),from,00005D,to,06805D,(73430/790/00205),Friday,05,August,2022,16:36:50:00009
Address 09-02,5Q0 955 547 ,recoded (Long Coding),from,00005D,to,06005D,(73430/790/00205),Friday,05,August,2022,16:37:04:00009
Address 09-02,5Q0 955 547 ,recoded (Long Coding),from,06005D,to,06805D,(73430/790/00205),Friday,05,August,2022,16:41:37:00009
I also changed the function of the DRL so they blink with blinkers. That is why there are extra entries
Thank you
