Dynamic Turn Signal (problem)
Hi guys, i have bought dynamic turn signals from superskoda but when i connect it to power and turn signal on,brightness is very weak... I had no problem with aliexpress one just these from kopacek ..
Does anybody know hot to fix this? Maybe via obd11 and crank the voltage?
The mirror turn signals connect to the door control modules and I don't recall any settings to change the brightness/voltage 😕
If the original indicators worked fine, I would suggest you contact kopacek and see what they say. At a guess, you might have a faulty batch?
